Hytera BD505LF V1.02.05.002
selahaddin
hi, i am looking for cps software on my hytera bd505lf, i will install analog and dmr channels.
connection wiring diagram is required.
Do I have to buy my own cable? Thanks
There is software in this thread.
http://www.pmr-funkgeraete.de/forum/threads/hytera-bd505lf-cps-5-01-15-001.26317/#post-164714
If you have a Motorola cable with the narrow double plug it might fit.
Or a China cable with the 8 plugs.
https://uk.aliexpress.com/item/32805822546.html?gatewayAdapt=glo2deu
Here you can search for sellers in the country where you live.
https://hytera-europe.com/accessories/pc76
Greetings Walter
Thanks
Greetings Walter
Thanks, I ordered a Wasserbüffel cable, I will write the result.
did this when upgrading :(
bd505 tag this help please
I'm looking for an upgrade kit suitable for the device, now it's stuck in the upgrade. open the new rcdb file failed! error and not progressing?
Yes, the annoying topic.... CPS must match the firmware.
Bootloader is renewed and then nothing works.
Thank goodness you can undo it and try a different CPS and firmware.
Unfortunately, the individual versions are not well documented on the manufacturer's website.
You have to try a lot yourself with the risk that something will go wrong....
This is exactly why the devices from Motorola, Hytera BDFX etc sometimes suspicious.
It takes a lot of time and searching to find the right one.
Then the software is still partially faulty.
Information from the manufacturer is rarely available.
Reported errors are simply ignored.
Much luck....
Read here
google knows that too...
