Midland G14
Hab ich beim Schnüffeln gefunden.
Kommt das auch oder nur ein Prototyp?
Auch verkauft Midland jetzt das Wouxun oder Albrecht.
Bezeichnung CT 790
Midland G14
Multifunctional PMR446 transceiver
Midland G14 is a PMR446 professional transceiver that
combines the latest technology in radio communication
along with a sturdy mechanical frame. It’s the best
and effective solution for the professionals who need to stay
in touch with colleagues in construction sites, buildings,
hotels, trade fairs or shows.
Midland G14 is equipped with a Li-Ion battery pack to
guarantee maximum performance and maximum life span.
All the functions are shown on the wide LCD display and
easily settable through the selection knob.
This transceiver is also equipped with a Scrambler function
that is designed to protect communications.
This feature prevents parties from other networks from
hearing and understanding voice communications.
It is possible to extend the flexibility and the features of
your radio through the specific PRG G14 programming
software (optional).
Accessories jack: KENWOOD 2 pin
COLOUR: black
SINGLE PACKAGE Code: C901
1 G14 transceiver
1 belt clip
1 wall adapter
1 1200mAhLi-Ion rechargeable battery pack
1 desktop charger
1 user manual
MAIN CHARACTERISTICS
• PMR446 Transceiver
• Output power: 500mW
• Channel spacing: 12.5KHz
• Channels: 8 PMR446 channels+ 91 pre-set channels
• Backlit LCD display adjustable in 3 different colours.
• 50 CTCSS and 105 DCS selectable codes
• Keypad lock function
• 2 SCAN modes: all channels SCAN and PRIORITY CHANNEL SCAN
• Emergency alarm
• Built-in VOX function (vocal-activated conversations)
• Scrambler function
• Busy Lock Out function
• Time-out Timer function
• Auto power save: for maximum battery life
• High/low selectable output power
• Low battery level indicator
• External jack for microphone or speaker (2 pin KENWOOD)
With the PRG G14 programming software (Code: C902) it is possible to:
- modify the output power
- Customize channels and frequencies
- Enable/disable specific functions
Hm,
das G14 schaut aus wie ein Puxing irgendwas oder das Midland CT-410 UHF-Gerät als PMR446-Version.
Naja, ob man das auch noch braucht. Langsam werden es einfach zuviele Geräte.
Das CT-790 - nunja, als Ergänzung für das CT210/CT410 sicher interessant, aber ob das nach DL kommt,
ist fraglich. Hier läuft es als Albrecht sicher besser.
Von Team kommt übrigens auch noch einiges Neues dieses Jahr :)
Zu Team hab ich keinen Draht.
Lass mich überraschen.
Ja wird langsam unübersichtlich.
Bei Alibaba.com(heist wirklich so!) kann man sich tausende
Gerätchen anschaun aus weltweiter Produktion.
Handfunken gibts schon genug,einen mobilen Duobander
aus der Wouxun Schmiede wäre nicht schlecht.
Ist aber nur für AFU interessant,
PMR und Freenet User können damit nichts anfangen(legal!)
Dann schaun mer mal.
Also, das Midland G14 kommt auch nach DL. Schauen wir mal, wann. Soll noch etwas dauern.
Dann kommt da noch ein Midland G9, Preis wie G8, auch als PMR446/LPD-Kombi oder reines PMR erhältlich.
Von Team gibt es folgende Neuheiten:
(ohne Kommentar, kein Termin bekannt, laut Team dauert es noch)
Das Tecom PS dürfte dir bekannt vorkommen ;)
Der kleine Ohrhörer-UHF-Empfänger könnte interessant werden, mal sehen, was der taugt.
G14 wird wohl auch einige Fans bekommen.
Zu den Team Geräten.
Hab ich baugleiche(ob genau gleich?) hier und ausgehend getestet.
Natürlich nicht von Team,sondern gleiche Exemplare.
Das Tecom PS kommt bestimmt mit USB Lader so wie das PX2R.
Über Umwegen lässt sich dort mit der SW auch 6,25 Khz einstellen,normal nur 12,5 KHz Raster.
Mal sehen ob es in etwa gleich ist.
Das T-Com X5 wird bestimmt ein Renner,hab ein baugleiches hier und bin begeistert.
Noch lautere NF und bessere Modulation und Empfänger wie die Wouxun KGUVD1P.
Prima Sound im UKW Betrieb.
Super kompakt und gute! kurze Antenne,3 Leistungsstufen(1W,2W,4W),einstellbar über Tastatur.
Alle Frequenzraster,Scrambler,schaltbarer Compander,super empfindliche Vox,DTMF De und Encoder uvm.
Dann hoffe ich das Team auch wirklich alle Features die möglich sind in das Gerät integrieren.
Es gibt von dem Gerät viele Versionen,mal mehr und mal weniger Features.
Ein Nachteil hat das Gerät,ist nur eine 70cm Funke.
Der kleine Ohr Empfänger kenne ich noch nicht ist mir neu,
findet aber bestimmt auch seine Abnehmer.
